Normal Topic Diagramming for silverlight (Read 2640 times)
fiary520
Mar 19th, 2010 at 2:00am
I am using LoadFromString(String str) method to load diagram i saved by SaveToString(SaveToStringFormat.Xml) method.But I failed,the error is Arg_NullReferenceException.In addtion,I use custom item types but not the ShapeNode class.
Re: Diagramming for silverlight
Reply #1 - Mar 19th, 2010 at 5:50am
Try calling Diagram.RegisterItemClass to register an XML name for the custom type, and also adding a constructor that takes a single Diagram argument for deserialization.
