Normal Topic AnchorPoint constructor (Read 1487 times)
BudMan
Credidi me felem vidisse
Mar 23rd, 2010 at 3:43pm
I have been playing around with the FlowCharter sample and tried to change the AnchorPoints of the "Alternative" node so their MarkStyles are rectangles and their color is green. Specifically, I changed the constructor code from this:
New AnchorPattern(New AnchorPoint() _
        { _
         New AnchorPoint(50, 0, True, True, MarkStyle.Circle, defAnch), _
         New AnchorPoint(0, 100, True, True, MarkStyle.Circle, defAnch), _
         New AnchorPoint(50, 100, True, True, MarkStyle.Circle, defAnch), _
         New AnchorPoint(100, 100, True, True, MarkStyle.Circle, defAnch) _
to this:
        { _
         New AnchorPoint(50, 0, True, True, MarkStyle.Rectangle, Color.Green), _
         New AnchorPoint(0, 100, True, True, MarkStyle.Rectangle, Color.Green), _
         New AnchorPoint(50, 100, True, True, MarkStyle.Rectangle, Color.Green), _
         New AnchorPoint(100, 100, True, True, MarkStyle.Rectangle, Color.Green) _
However, when I run the program and drag an Alternative shape unto the diagram, it still shows red circles for the AnchorPoints. On the other hand, I see that the AnchorPoints sample progam DOES show various AnchorPoints correctly. I cannot figure out why the code works there but not the FlowCharter app.
I am running trial version 5.3.3 of FlowChart.NET.
Thanks for your help in solving the mystery.
Re: AnchorPoint constructor
Reply #1 - Mar 23rd, 2010 at 3:57pm
Check the for-each loop in the _flowChart_DragDrop handler Wink I suppose we have added this dialog for changing the points appearance after the first release of the sample; now the handler sets the color from the options, so the colors from the init code do not matter much.
BudMan
Reply #2 - Mar 23rd, 2010 at 8:52pm
That worked! Thanks.
