Normal Topic Need Custom Shaped Selection Handle (Read 3552 times)
Bala
Mar 24th, 2010 at 6:54am
Hi Stoyan,
In our application, we have some custom shaped ShapeNode(like pentagon, hexagon and  etc.)
We are using DrawAdjustmentHandle() of diagram to draw selection rectangle for these shapes, but we are not able to find any method which accepts Shape as an argument.
Please suggest how we can draw Custom Selection Handle for our Custom Shaped Nodes.
Bala
Re: Need Custom Shaped Selection Handle
Reply #1 - Mar 24th, 2010 at 11:38am
Hi Bala,
Do you need to draw a selection border with the same shape as the node? You could use the Shape.Draw method for that. It draws the shape with its definition coordinates in the 0-100 range, so you will need to first apply a scale transform such as dc.ScaleTransform(nodeWidth / 100, nodeHeight / 100) .
Bala
Reply #2 - Apr 1st, 2010 at 5:20am
Hi Stoyan,
I have tried but not got desired output. I am sending the sample application please suggest the right way.
Anshul
Reply #3 - Apr 1st, 2010 at 11:54am
Hi Anshul,
It seems you are using an older version that does not have a public Shape.Draw method. Try the following instead:
if (e.Item is DiagramNode)
	DiagramNode node = e.Item as DiagramNode;
	e.Graphics.DrawGeometry(null, new Pen(Brushes.Red, 3), node.GetRegion());
Bala
Reply #4 - Apr 1st, 2010 at 2:57pm
Thanks Stoyan Smiley
