Normal Topic Drawing Horiz Link From AnchorPoint (Read 1353 times)
BudMan
Credidi me felem vidisse
Mar 26th, 2010 at 3:24pm
I am trying to create a horizontal link from a specific anchor point (on a shape node) to a point 25 units to the right. The rightmost point is not connected to a node. The code I am using is the following, but does not draw the link where I want.
       Dim l As DiagramLink
       Dim pt1, pt2 As PointF
       pt1 = New PointF(MyNode.Shape.AnchorPattern.Points(1).X, _
               MyNode.Shape.AnchorPattern.Points(1).Y)
       pt2 = New PointF(MyNode.Shape.AnchorPattern.Points(1).X + 25, _
      l = dgm.Factory.CreateDiagramLink(pt1, pt2)
Could you please show me the right code? I know I am not using the correct offsets for the X and Y but can't figure them out. Or maybe there is a simpler way.
Re: Drawing Horiz Link From AnchorPoint
Reply #1 - Mar 26th, 2010 at 3:50pm
The anchor point coordinates are percents of the node width and height. Their coordinates in the diagram should look like this:
diagramX = nodeLeft + nodeWidth * anchorX / 100;
diagramY = nodeTop + nodeHeight * anchorY / 100;
BudMan
Reply #2 - Mar 26th, 2010 at 4:50pm
Thanks, that worked perfectly.
