Normal Topic Shapenode and multiple shape (Read 1525 times)
rajesh_patil74
Mar 29th, 2010 at 7:25am
Hi Stoyo
Is it possible to have multiple shapes for a shapenode like in following fig.
As of now, I need minimum two additional shape support for the shapenode.
Is it possible to make this in release 1.4 or release 1.5.
Regards
Rajesh
Re: Shapenode and multiple shape
Reply #1 - Mar 29th, 2010 at 8:23am
It is possible by adding decoration / filled decoration elements to the Shape, e.g. as in BPMN shapes. Such decoration elements scale proportionally to node.Bounds. If you don't want the decorations to scale, you could add Images or Paths to the ShapeNode template, and position them using a Grid container.
rajesh_patil74
Reply #2 - Mar 29th, 2010 at 8:51am
Hi Stoyo
Thanks !! . I did same thing right now. From usablity point, I think above point should be in mind fusion implementation.
Also, you can have something like following in your implementation -
1. Each node have one collection object similar to containernode having childern collection.
This collection can have following type of object - images, text and shapes.
For shape, user can specifiy the custom template for grid (rows, column and therir sizes. and user can specify the row,columns for each childern item and they gets rendered according to same.)
This allows, for each shape n number of child shapes and multiple text/image possiblities.
-Rajesh
