Normal Topic Shapenode and shadow using shapegemotry (Read 1235 times)
rajesh_patil74
Mar 29th, 2010 at 8:01am
Hi Stoyo
In my application, for node when i specify shadow, it gives me performance issue with scrolling. In one of your reply, you suggested use another nodes with by setting offset.
In Tutorial 3, I tried to use ShapeGeometry for rendering two shapes ( another one use few offset ) but that gives me xaml parsing error.
I used following code
<ControlTemplate TargetType="local:OrgChartNode">
<Canvas x:Name="Adorner">
<Path Data="{TemplateBinding ShapeGeometry}"
Stroke="{TemplateBinding Stroke}"
Fill="{TemplateBinding Brush}" />
<Path Canvas.Left="20" Canvas.Top="20"
Fill="Black" />
</Canvas>
Can you help me in this regards.
-Rajesh
Re: Shapenode and shadow using shapegemotry
Reply #1 - Mar 29th, 2010 at 10:08am
It seems Silverlight does not allow DependencyObjects to be shared between more than one visual parents. We had a similar problem with StrokeDashArrays, and as a workaround used an IValueConverter that clones the specified dash array and assigned such converter to the binding. In this case the following works fine:
public class GeometryConverter : IValueConverter
	public object Convert(object value, Type targetType, object parameter,
		System.Globalization.CultureInfo culture)
		if (targetType == typeof(Geometry))
			ShapeNode src = value as ShapeNode;
			if (src != null)
				return src.Shape.CreateOutlineGeometry(src.Bounds.Width, src.Bounds.Height);
		return value;
	public object ConvertBack(object value, Type targetType, object parameter,
		throw new NotImplementedException();
<Canvas.Resources>
	<local:GeometryConverter x:Key="geometryConverter"/>
</Canvas.Resources>
<Path Canvas.Left="30" Canvas.Top="30"
	Data="{Binding Path=., RelativeSource={RelativeSource TemplatedParent}, Converter={StaticResource geometryConverter}}"
	Fill="Black" />
