Normal Topic Custom hanldles UI (Read 1557 times)
Denis_Vuyka
Custom hanldles UI
Mar 29th, 2010 at 6:53pm
I need providing more beautiful handles than squares (special icons for instance). What should I override in order to replace default ones?
Re: Custom hanldles UI
Reply #1 - Mar 30th, 2010 at 8:36am
The handles are defined as protected List<System.Windows.Shapes.Shape> handles; so you won't be able to replace them with Image controls, but you could paint them using an ImageBrush. Try to override AddHandlesToCanvas(positions) and after calling the base method loop over the handles list and set the shapes' Brush.
Denis_Vuyka
Reply #2 - Mar 31st, 2010 at 1:15pm
Thanks this workaround helped. However it is good to have such support out of box. At least the property for the brush.
