Normal Topic new Public property (Read 6308 times)
BidMaestro
to learn is to live
new Public property
Mar 30th, 2010 at 11:39am
Guys
The work with my client using Flowchart.Net has me making use of the Tag property field on shapenodes for a variety of purposes, one of which is the use of a unique Guid field used in database records to associate data with shapenodes.
It would be nice if every shapenode/diagramnode/link had a Guid Id field to uniquely identify the items and for greater integration between Flowchart.net and database records.
Let me know if this does not make sense.
Doug
Re: new Public property
Reply #1 - Mar 31st, 2010 at 6:20am
It does, but a Guid type will limit the kind of ids you can associate with nodes. We could make it and "object Id" property, and let you associate integer / string / guid values with it. I suppose this would not be any different from Tag, but will only provide an additional field for custom data.
BidMaestro
to learn is to live
Reply #2 - Apr 3rd, 2010 at 3:00am
Sorry for the delay in getting back to you.
Having another field ''object type" would be fine as everyone has different needs. Given that I and probably many other developers are linking the chart to a database the use of an additional data field would be tremendous.
For instance I access a database to gather the data for charting; I record key items of information in a record structure (below) that I store information in the .Tag field which can be interrogated at anytime without going back to the database.
Having a separate data field like .tag would be great in my case for storing a unique id for the node and leave the tag to contain my other data elements.
regards
Doug :)
    Structure NodeDetails
       Dim Node_ProjectID As Guid
       Dim Node_EntityID As Guid
       Dim Node_RealEntity As Boolean
       Dim Node_ParentID As Guid
       Dim Node_EntityType As enmEntityType
       Dim Node_DescOfEntity As String
       Dim Node_GroupID As String
    End Structure
Reply #3 - Apr 22nd, 2010 at 9:04am
Hi Doug,
This version adds an Id property to DiagramItem:
https://mindfusion.eu/_beta/diagwin_535.zip
BidMaestro
to learn is to live
Reply #4 - Apr 22nd, 2010 at 9:20am
Absolutely brilliant; I hope than many developers can make use of this additional id property for linking diagram and shape nodes to their databases or for many other valid uses.
Well done; you certainly are one of the best product developers who listens to and implements user suggestions that have value to others.
regards
Doug Smiley Smiley Smiley
« Last Edit: Apr 22nd, 2010 at 1:13pm by BidMaestro »
