Normal Topic Jdiagram sizing issue. (Read 3903 times)
Mrini
Mar 31st, 2010 at 9:05am
Jdiagram's diagram behaves in different manner on different platforms.
I have used the two linktables for source and target mappings.
the size of the tables are relative to the diagram.
It appears proper on window , but differ on Linux ( for fedora it stretches and on Red Hat it shrinks).
Is there any solution over this.
thanks.
jay
Re: Jdiagram sizing issue.
Reply #1 - Mar 31st, 2010 at 9:30am
it may be resolution issue.
Reply #2 - Mar 31st, 2010 at 10:52am
Are you using the default MeasureUnit value?
Mrini
Reply #3 - Mar 31st, 2010 at 11:10am
I am not specifying MeasureUnit so it must be using default.
I also tried with GraphicsUnit.Point and GraphicsUnit.Pixel but it doesn't work properly.
can you please specify which unit to used.
Reply #4 - Mar 31st, 2010 at 12:09pm
The control calls Toolkit.getScreenResolution() to determine what scale to apply for each unit, and that method should be getting the DPI from a system setting somewhere.
You might set the unit to Pixel, and the graphics won't be scaled, but use the Java Point unit. The point should be always a 72 DPI, but it might depend on the same system setting returned by getScreenResolution(). If you change the unit, you must also update all size values used in the diagram so that they correspond to the new unit.
Mrini
Reply #5 - Mar 31st, 2010 at 1:25pm
can you please give an example how can i set the bounds for linktable according to different OS.
Reply #6 - Mar 31st, 2010 at 6:03pm
I can't. You will have to somehow set the correct DPI value for the display on that system. As a lost resort, you can use ZoomFactor to fix the scale. However if Toolkit.getScreenResolution() does not work, you won't be able to automatically find out what's the correct scale.
