Normal Topic Subclassing the ShapeNode (Read 1559 times)
BudMan
Credidi me felem vidisse
Mar 31st, 2010 at 4:19pm
I created a subclass of the ShapeNode class as follows:
               Public Class MyShapeNode
         Inherits ShapeNode
End Class
The reason I did this is because I want to add properties to the MyShapeNode class that the base class does not have.
To instantiate a MyShapeNode object I then wrote code like this:
Dim fnode As MyShapeNode = CType(dgmMain.Factory.CreateShapeNode(pt.X, pt.Y, 20, 20), MyShapeNode)
The text editor accepted the code, but when I ran the program, it threw an InvalidCastException. Maybe I need to go back to OOP school, but should this not work?
Re: Subclassing the ShapeNode
Reply #1 - Mar 31st, 2010 at 5:57pm
The Factory methods create items only from the standard node classes. You can add an instance of a custom class to the diagram through the Nodes collection:
gdmMain.Nodes.Add(New MyShapeNode(...))
BudMan
Reply #2 - Mar 31st, 2010 at 8:59pm
That did the trick. I wrote the following as a replacement for the Factory.CreateShapeNode method that accommodates subclasses:
               fnode = New MyShapeNode
               dgmMain.Nodes.Add(fnode)
               fnode.Bounds = New RectangleF(pt.X, pt.Y, 20, 20)
This way I can subsequently assign values to the subclass' properties.
Thanks again for the quick response.
