Normal Topic Brush Serialization (Read 2310 times)
BudMan
Credidi me felem vidisse
Brush Serialization
Apr 2nd, 2010 at 2:05pm
I want to store a ShapeNode's Brush in a database. I know that I did this in Planner.NET  by serializing it using this method:
MindFusion.Drawing.Brush.Serialize
That was years ago. Apparently that method is no longer available, at least in the FlowChart.NET Drawing assembly. Is there some other method you are using as a replacement?
Re: Brush Serialization
Reply #1 - Apr 2nd, 2010 at 3:20pm
The method is still there, but it has the EditorBrowsableState.Never attribute set. So Intellisence won't show it in the auto completion drop-down, but you can still use it and the project should compile fine.
BudMan
Reply #2 - Apr 2nd, 2010 at 4:05pm
That worked. And I can see both the Serialize and Deserialize methods in Object Browser if I check the 'Show Hidden' option.
Just out of curiosity why would you hide those methods? We database app developers find them useful for saving Brush, Pen, etc. data.
Reply #3 - Apr 6th, 2010 at 5:44am
Now there is a TypeConverter associated with Brush that allows converting Brush-derived objects from / to string, and I suppose our developer might have decided that's enough...
Many .NET services use type converters automatically (possibly data-binding too), but you can also explicitly get a converter and apply it like this:
TypeConverter converter = TypeDescriptor.GetConverter(e.Node.Brush);
string brushString = converter.ConvertToString(e.Node.Brush);
