Normal Topic Creating Links From ControlPoints (Read 2398 times)
BudMan
Credidi me felem vidisse
Apr 5th, 2010 at 10:53pm
Is it possible to construct a link using just control points and the Links.Add method? I have tried to do this with code like the following:
       Dim pt1, pt2 As PointF
       Dim lnk As New DiagramLink(dgm)
       pt1 = New PointF(40, 40)
       lnk.ControlPoints.Add(pt1)
       pt2 = New PointF(60, 60)
       lnk.ControlPoints.Add(pt2)
       lnk.Pen = New MindFusion.Drawing.Pen(Color.Red, 1)
       dgm.Links.Add(lnk)
This does not work. Yet I know the Add() method works for nodes. Is the same not possible for links? Or do I have to use the Factory.CreateDiagramLink() method?
Re: Creating Links From ControlPoints
Reply #1 - Apr 6th, 2010 at 6:08am
You can use the Factory methods that take PointF arguments. If you need to add a custom link instance:
Dim lnk As New DiagramLink(diag)
lnk.Origin = Nothing' create a DummyConnectionPoint
lnk.Destination = Nothing' create a DummyConnectionPoint
lnk.ControlPoints.Clear()
lnk.ControlPoints.Add(New PointF(40, 40))
lnk.ControlPoints.Add(New PointF(60, 60))
lnk.UpdateFromPoints(False, True)
diag.Links.Add(lnk)
BudMan
Reply #2 - Apr 12th, 2010 at 3:42pm
Thanks, Stoyo, that worked great. The user can now manually re-route links to suit and save the new controlpoints in a database.
The only problem is the ArrowHead often points in the wrong direction when the diagram is re-opened. For example, say FlowChart initially draws a link with the last segment pointing to the left. The user then changes the link so the last segment points down and saves to a database. Often when the diagram is re-loaded, the new route is shown correctly but the ArrowHead itself still points to the left(or right), not down. That is, the way it was when it originally drew the link.
I know I could avold this by using the Circle as the LinkHeadShape, but hope you can tell how to correctly render the arrow.
Reply #3 - Apr 12th, 2010 at 3:45pm
Do you call UpdateFromPoints after restoring points from the database?
BudMan
Reply #4 - Apr 12th, 2010 at 4:35pm
Perfect! Thanks.
