Normal Topic How to enable scroll functionality in the diagram? (Read 2412 times)
venki5star
Apr 7th, 2010 at 12:33pm
I have a diagram of width 400 with the below property settings,
AutoScroll = "true"
ScrollViewer.CanContentScroll = "true"
If i move a node beyond the width of the diagram, i assumed i will get a scroll bar, but it didn't work.
Is there a way to enable it? Please help.
Castle Rider
Re: How to enable scroll functionality in the diag
Reply #1 - Apr 7th, 2010 at 12:56pm
Try also setting the Diagram.AutoResize property.
venki5star
Reply #2 - Apr 7th, 2010 at 1:03pm
I tried setting AutoResize="RightAndDown", but i am not able to see the scrollbar.
Do we have to put the diagram inside a scrollviewer, doesn't the diagram has an inbuilt scrollviewer?
Castle Rider
Reply #3 - Apr 7th, 2010 at 1:08pm
Yes, you must place it either inside a ScrollViewer or a Ruler.
venki5star
Reply #4 - Apr 7th, 2010 at 2:32pm
Thanks Stoyan. It helped.
Castle Rider
