Hot Topic (More than 10 Replies) DocumentPaginator Creates Blank Pages (Read 10312 times)
Re: DocumentPaginator Creates Blank Pages
Reply #15 - Aug 9th, 2010 at 11:50am
The control should print the rectangular area that fits all items, but won't skip pages from that area even if they contain nothing. E.g. if there are items only at the upper left and lower right of the diagram, some pages on the second diagonal might be empty. Is that the problem, or are you getting larger print area than necessary?
Bastian
Reply #16 - Aug 9th, 2010 at 12:55pm
Your last observation is correct. Pretend i have a rectangle, diveded in 4 pages. So normally on every paper you get a corner of the total rectangle. In my case i need 6 pages with page 3 and 4 are blank.
Reply #17 - Aug 9th, 2010 at 5:45pm
By pages #3 and #4 of total 6, do you mean the middle row of 2 columns x 3 rows of document pages? Could you email to support@mindfusion.eu a sample diagram showing that?
Bastian
Reply #18 - Aug 10th, 2010 at 6:41am
You are correct, hopefully you have a solution.
Reply #19 - Aug 10th, 2010 at 7:22am
This means these pages are part of the content rectangle then, and they are printed even if they don't contain items. That's by design, the idea being you would print a big diagram and glue the pages or stick them on the wall. Since you have the source code, you can add some property to skip empty pages, or our developer can do that if you renew your maintenance - the choice is yours.
