Normal Topic ShapeToolbar AllowDrag (Read 4145 times)
BidMaestro
to learn is to live
Apr 8th, 2010 at 1:16am
Hi all
I have been using the ShapeToolbar for some time now and just noticed a problem. The AllowDrag property if set to false still accepts a shape drag and drop from the ShapeToolbar onto the diagram area
Doug ???
Re: ShapeToolbar AllowDrag
Reply #1 - Apr 8th, 2010 at 5:52am
Our bad. We have fixed this now and will release v5.3.4 with the fix in a couple of days.
BidMaestro
to learn is to live
Reply #2 - Apr 8th, 2010 at 6:52am
One of the new things that I was doing was on the diagramview.dragdrop to create a  new node using the shapetoolbar.selectedshape. That worked OK however the shapetoolbar shape was also dropped on to diagram area. Possibly this is something that I am doing. What I am trying to achieve is to add text to the node created from the selected shape from the toolbar when it is dropped on the diagramview
Doug
Reply #3 - Apr 8th, 2010 at 8:54am
Hi Doug,
The builtin drag and drop handler raises the NodeCreated event, so you might try adding the text from the NodeCreated handler.
BidMaestro
to learn is to live
Reply #4 - Apr 8th, 2010 at 11:04am
That did the trick, thank you.
Doug
Wink
