Normal Topic Node reposition changes the start/end point (Read 1092 times)
rajesh_patil74
Apr 8th, 2010 at 10:04am
Hi Stoyo
I have following orgonogram diagram. In this diagram I calculated the position of nodes and points for link [ so that I can have leaf node management as shown in fig. ]
Now if I change the node position little bit, for all the links linked to that node changes their start and end points.
How those end points will be preserved and autoroute gets applied to upto immediate point of that link connected to start/end point. [In my diagram, the center point should be adjusted.]
Applying link.Route or Autoroute gives me lines with more or less segements.
Addition info :- This happens only first time. Now If i try to reposition it again after the second image effect it doens't change start/end points of those links [ Their attached position with the nodes ].
-Rajesh
Re: Node reposition changes the start/end point
Reply #1 - Apr 8th, 2010 at 12:48pm
Hi Rajesh,
Do you call UpdateFromPoints after setting the points?
