Normal Topic Node resizing with mouse wheel is forgotten (Read 1361 times)
abereznyi
Apr 9th, 2010 at 4:13pm
I use MouseWheel event to make node width/height bigger or smaller and it works very nicely.
However, after I make node bigger this way and then click on it to select, it shows handles corresponding to the old (smaller) size, and when I drag this node to a new location, it's also reverts to the old size.
It seems that my node size change is somehow completely forgotten. Do I miss something here or may be this problem needs fixing?
&&Thanks,&&Alex
Re: Node resizing with mouse wheel is forgotten
Reply #1 - Apr 9th, 2010 at 4:40pm
I suppose this might happen if you set the inherited Width and Height properties. Try setting the node's Bounds instead.
abereznyi
Reply #2 - Apr 9th, 2010 at 5:00pm
Yes, setting Bounds works correctly!
Alex
&&Thanks,&&Alex
