Normal Topic Diagram Pasting Nodes (Read 3939 times)
BidMaestro
to learn is to live
Apr 11th, 2010 at 5:56am
I am not sure if this is a bug or my lack of understanding. In the application that I am building I have code that prevents a user from adding more that 2500 nodes to the Diagram area.
I test the node.count at the diagram.nodecreated and diagramview.dragdrop code. Adding more nodes to a diagram that already has 2,500 is stopped.
However, if I copy a group of nodes already on the diagramview area and paste them on the diagramview area it does not trigger the nodecreated. I used the diagram.nodepasted and added code to issue a message however I could not cancel/prevent the paste action. Is there a way to clear the clipboard?
Doug
« Last Edit: Apr 11th, 2010 at 7:06am by BidMaestro »
Re: Diagram Pasting Nodes
Reply #1 - Apr 11th, 2010 at 8:46am
You could paste to a temporary diagram to see how many items are there in the clipboard, and do not call Paste on the main diagram if that would bring the count to more than 2500.
BidMaestro
to learn is to live
Reply #2 - Apr 11th, 2010 at 8:58am
That sounds like a good work around; I will try that later. I will explore testing the count at the copy stage also.
At some stage in the future you may want to think about a clear clipboard command or cancel coyp or paste.
Have a great week.
Doug
BidMaestro
to learn is to live
Reply #3 - Apr 11th, 2010 at 10:23am
I have a simple solution.
At the time of copying the nodes I record the count of selected nodes.
NodeSelectionCount = Diagram1.Selection.Nodes.Count
At the time of pasting I check the number of nodes on the diagram plus the count of nodes on the clipboard and if the total exceeds 2500, I do not perform the paste.
                   If Diagram1.Nodes.Count + NodeSelectionCount > 2500 Then
                       ' Issue message
                   Else
                       dvMain.PasteFromClipboard(Xcoords, Ycoords, True)
                       NodeSelectionCount = 0
                   End If
Doug
