Normal Topic Pathfinder example (Read 1570 times)
BidMaestro
to learn is to live
Pathfinder example
Apr 12th, 2010 at 9:00am
I could not find a sample vb program that displays pathfinder working. Can you point me in the right direction for a demo.
Doug
Re: Pathfinder example
Reply #1 - Apr 12th, 2010 at 1:17pm
For example this prevents user from drawing cycles in the diagram by means of PathFinder:
Private Sub diag_LinkCreating(ByVal sender As System.Object, ByVal e As MindFusion.Diagramming.LinkValidationEventArgs) Handles diag.LinkCreating
	Dim finder As New PathFinder(diag, True)
	If finder.FindShortestPath(e.Destination, e.Origin) IsNot Nothing Then
		e.Cancel = True
	End If
End Sub
You can also find a VB version of the FCDemo sample project below; it has some pathfinding shown in one of the steps:
https://mindfusion.eu/_samples/DemoVb.zip
BidMaestro
to learn is to live
Reply #2 - Apr 12th, 2010 at 1:57pm
Thank you; I had created a basic example for myself however I wanted to see some examples. In the provided demo there is a PathFinding example under Graph management which has give me a few more ideas.
Doug
