Normal Topic CreateImage for client area (Read 3865 times)
BidMaestro
to learn is to live
Apr 13th, 2010 at 7:11am
I have looked through the forum however I could not see if there is a method of captuing an image of the current diagramview area on screen; not the whole diagram as in using the CreateImage.
Is there a way of capturing what is on the client area screen in front of me?
Smiley
Doug
Re: CreateImage for client area
Reply #1 - Apr 13th, 2010 at 7:34am
Hi Doug,
There's the following overloaded method:
public Bitmap CreateImage (RectangleF viewport, float scale)
Pass ClientToDoc(view.ClientRectangle) as viewport value to get only the view's client area exported.
BidMaestro
to learn is to live
Reply #2 - Apr 13th, 2010 at 9:05am
Thank you; I am a dope when converting code statements from C to VB.
I have the part where I capture the clientarea
       Dim viewport As RectangleF
       viewport = dvMain.ClientToDoc(dvMain.ClientRectangle)
However I am missing the next part of the logic creating the image from the viewport value
Doug
Reply #3 - Apr 13th, 2010 at 11:55am
Doesn't dvMain.Diagram.CreateImage(viewport, 100) work?
BidMaestro
to learn is to live
Reply #4 - Apr 13th, 2010 at 12:23pm
Hi Stoyan
That worked perfectly; sorry it has been a long day here today.
Once again, thank you for the expert assitance.
I downloaded the 5.3.4 beta and hope to give it a few tests later in the week.
Doug
Reply #5 - Apr 13th, 2010 at 12:46pm
Hi Doug ,
Don't bother with the beta, we are releasing it now.
BidMaestro
to learn is to live
Reply #6 - Apr 13th, 2010 at 1:13pm
I look foward to it. Grin
Doug
