Normal Topic Multiple days vertically in Timetable view (Read 3474 times)
martmuller
Apr 14th, 2010 at 11:10am
Can you tell me if it is possible to dislay more then one day in the vertical timeline of the timetable view?
I found out that it possible to set the start and end time, but only for that day.
What i would like to achieve is the resource view but then vertically. Right now I use the timetable grouped by resource, which is exactly what I want. In our case, sometimes the working days go from 9am to 3am the next morning...
Hope you can help me with this one? Great control by the way!
Mart
Re: Multiple days vertically in Timetable view
Reply #1 - Apr 14th, 2010 at 11:51am
Presuming that your Calendar is identified by the calendar variable, try the following settings:
calendar.TimetableSettings.StartTime = 540; // 9 AM
calendar.TimetableSettings.EndTime = 1620; // 3 AM on the following day
Additionally, you can set the work time interval to 9AM - 3AM by using the following code:
calendar.TimetableSettings.WorkTimeStartHour = 9;
calendar.TimetableSettings.WorkTimeEndHour = 27;
Let me know if this helps.
martmuller
Reply #2 - Apr 14th, 2010 at 12:03pm
Thanks, works like a charm!
