Normal Topic Diagram not resizing inside Ruler. (Read 2128 times)
venki5star
Apr 15th, 2010 at 6:44am
I have a diagram placed inside the ruler. If the window's width is 1000, then the ruler automatically fills in the width, but not the diagram.
It is always aligned in the middle of the ruler.
How do i make the diagram fill the ruler?
Sent you a sample project for this (from email surendra@eagle-india.com)
Please help.
Castle Rider
Re: Diagram not resizing inside Ruler.
Reply #1 - Apr 15th, 2010 at 11:21am
The size of the diagram depends only on its Bounds property. You could handle the SizeChanged event raised for the diagram’s container - Ruler or Scroll Viewer - and set larger Bounds value if you detect it's smaller than the container's ActualWidth / ActualHeight.
venki5star
Reply #2 - Apr 15th, 2010 at 1:07pm
It doesn't seem to solve the problem, i have sent you one sample in which i tried.
Please help.
Castle Rider
Reply #3 - Apr 16th, 2010 at 12:43pm
Change this line:
MyDiagram.Bounds = MyRuler.Document.Bounds;
which assigns diagram.Bounds to itself, to:
var scrollViewer = MyDiagram.Parent as ScrollViewer;
var b = MyDiagram.Bounds;
if (scrollViewer != null)
     MyDiagram.Bounds = new Rect(0, 0,
           Math.Max(scrollViewer.ActualWidth, b.Width),
           Math.Max(scrollViewer.ActualHeight, b.Height));
venki5star
Reply #4 - Apr 16th, 2010 at 12:49pm
This fixed the issue.
Thanks Stoyan.
Castle Rider
