Normal Topic How to capture KeyDown event on Flowchart box? (Read 3218 times)
bitbit
Apr 15th, 2010 at 9:49am
I would like to capture 'Ctrl + C' event after a user clicks to rename a flow chart box. How do I capture events on a fcBox?
I can capture keydown event for a map:
this.fcMap.KeyUp += new System.Windows.Forms.KeyEventHandler(this.fcMap_KeyUp);
But how about a flowchart box?
BitByBit
Re: How to capture KeyDown event on Flowchart box?
Reply #1 - Apr 15th, 2010 at 10:55am
Handle the EnterInplaceEditMode event and add a handler to the event's EditControl argument.
bitbit
Reply #2 - Apr 15th, 2010 at 11:28am
Thanks for the reply but I am not understanding how to implement your suggestion.
Could you provide me with a code snippet please?
bitbit
Reply #3 - Apr 15th, 2010 at 11:39am
Hi Stoyo
I have created this method:
fcMap_EnterInplaceEditMode(object sender, InplaceEditArgs e)
Now, e has Item and TextBox as its properties. What should I do?
Should I catch e.TextBox's keydown event?
If yes, how can I do that?
Sorry for too many questions but I am desperate for the solution.
Hope you will bail me out!
Reply #4 - Apr 15th, 2010 at 1:04pm
Yes, add a handler to the TextBox control:
e.TextBox.KeyDown += new KeyEventHandler(this.fcMap_KeyUp);
We have renamed it to EditControl in recent versions, because now you can use other controls instead of TextBoxes.
