Normal Topic How to set DataContext for ShapeNode? (Read 2029 times)
venki5star
Apr 20th, 2010 at 10:58am
I have a shape node which is created using the following code,
diagram.Factory.CreateShapeNode(...
I wanted to set the DataContext for the created node, how to achieve this?
Please help. Its very urgent.
Castle Rider
Re: How to set DataContext for ShapeNode?
Reply #1 - Apr 20th, 2010 at 12:46pm
ShapeNode does not derive from FrameworkElement and does not have DataContext property. You'll have to use controls wrapped in DiagramNodeAdapters if you need to databind nodes.
venki5star
Reply #2 - Apr 20th, 2010 at 2:12pm
Do you have any sample for this?
Castle Rider
Reply #3 - Apr 21st, 2010 at 10:26am
For example you can let users draw ListViews or other FrameworkElements as below:
public partial class Window1 : Window
	public Window1()
		InitializeComponent();
		diagram1.DefaultControlType = typeof(ListView);
		diagram1.Behavior = Behavior.DrawControls;
	private void diagram1_InitializeNode(object sender, NodeEventArgs e)
		var patients = new[] { new Patient("Jhon", 28), new Patient("Roy", 40) };
		var listView = e.Node.UIElement as ListView;
		listView.ItemsSource = patients;
public class Patient
	public Patient(string n, int a)
		Name = n;
		Age = a;
	public override string ToString()
		return Name + " : " + Age;
	public String Name { get; set; }
	public int Age { get; set; }
Apart from ItemsSource you can set DataContext, ControlTemplate, DataTemplate etc. for the hosted FrameworkElements.
venki5star
Reply #4 - Apr 21st, 2010 at 2:40pm
Thanks Stoyan.
Castle Rider
