Normal Topic How can I get my custom node to size automatically (Read 2691 times)
cds
Apr 21st, 2010 at 3:23am
I am adding custom nodes to my diagram following the tutorial. My custom node is a control with a control template defined in generic.xaml which includeds a TextBlock for some text.
How can I measure the required size with the text set on the TextBlock and then set the node's bounds according to the width that the TextBlock requires?
Craig
Re: How can I get my custom node to size automatic
Reply #1 - Apr 21st, 2010 at 8:17am
The ShapeNode.ResizeToFitText method uses a temporary TextBlock to measure the text size:
var textBlock = new TextBlock
	Text = Text,
	TextWrapping = TextWrapping.Wrap,
	Width = double.NaN,
	Height = double.NaN,
	FontFamily = FontFamily,
	FontSize = FontSize
textBlock.UpdateLayout();
Size desiredSize = new Size(
	textBlock.ActualWidth + TextMargin.Left + TextMargin.Right + StrokeThickness * 2,
	textBlock.ActualHeight + TextMargin.Top + TextMargin.Bottom + StrokeThickness * 2);
You can do something similar for your nodes, and also add the size of any additional elements in their template to desiredSize.
cds
Reply #2 - Apr 21st, 2010 at 9:20am
Thanks Stoyan
That works nicely. I had something similar but was missing a couple of vital details.  Grin
Craig
