Hot Topic (More than 10 Replies) Get Grid Position of Nodes? (Read 5740 times)
mbuechler
Apr 21st, 2010 at 7:07am
Hi.
I have a diagram with several ControlNodes. For these ControlNodes I would like to save the Position in the underlying grid. Do I have the possibility to get the actual Position of an Item/node on the grid?
Thanks a lot.
Re: Get Grid Position of Nodes?
Reply #1 - Apr 21st, 2010 at 7:28am
You can get a node's position through its Bounds property. If you need to get the underlying cell of the lanes grid, call the grid's GetCellFromPoint method.
mbuechler
Reply #2 - Apr 21st, 2010 at 7:38am
Hi thanks for the answer.
But how do I get the grid from my diagram? I can only find :
diagram1.GridColor
diagram1.GridOffsetX
diagram1.GridOffsetY
diagram1.GridSizeX
diagram1.GridSizeY
diagram1.GridStyle
I mean the grid which helps the user to position the several Items. I do not mean any table,...
Thanks again
Reply #3 - Apr 21st, 2010 at 8:03am
It seems you are not using the LanesGrid then? If you need to determine where in the alignment grid (as column and row) some item is located, you can do that by subtracting the respective GridOffsetX/Y property from the item's position and dividing the result by GridSizeX/Y.
mbuechler
Reply #4 - Apr 21st, 2010 at 8:43am
Ah ok.
So there is no easy way to say "GetGridPosition", save this infos, and on loading the flowchart again say "SetGridPosition" for the Objects.
OK so I have to save X/Y Location...
Reply #5 - Apr 21st, 2010 at 9:46am
You can save and restore X and Y from node.Bounds. There wouldn't be much difference from storing columns and rows, except that X and Y are float values.
mbuechler
Reply #6 - Apr 22nd, 2010 at 8:35am
Ok I See.
Another Question is: I changed measure Unit of the diagram to Pixel, and now the Handles for resizing an item are very small. Where can I change Handlesize? Is it a property on the items or on the diagram.
Thanks again.
Reply #7 - Apr 22nd, 2010 at 9:06am
There's the Diagram.AdjustmentHandlesSize property.
mbuechler
Reply #8 - Apr 22nd, 2010 at 9:17am
Ah ok. Thats what I need. Thanks.
Is there also a posibility to enlarge the "border" with what you can move the item?
Reply #9 - Apr 22nd, 2010 at 10:06am
I think it is always set to half the AdjustmentHandlesSize at this time; there's no additional property to change just its size.
mbuechler
Reply #10 - May 3rd, 2010 at 8:53am
Thanks a lot.
I have another question about Links. Is there a property for a offset the links have? An offset between the anchor an the link itself? My problem is that a part of the head of the link is not shown. It is hidden by the Node where it is assinged to.
Thanks again
Reply #11 - May 3rd, 2010 at 9:01am
Call link.ZTop to move the head in front of the node. Otherwise you might try placing the anchor points a bit outside the node borders, or explicitly set ControlPoints[0] and ControlPoints[count - 1].
