Normal Topic Table node hiding behind Shape node. (Read 2279 times)
venki5star
Apr 23rd, 2010 at 10:30am
I have a table node which is attached to a shape node. I use the table node to show images on drop event. It worked fine, but now i could see the table node is behind the shape node and the images which i added dynamically goes behind and not displayed in the UI.
Is there a way in which i can force the table node to display on top. I tried setting the Zindex of the table node to an higher value than the shape node, but it didn't help.
Please help.
Castle Rider
Re: Table node hiding behind Shape node.
Reply #1 - Apr 23rd, 2010 at 11:46am
What ZIndex value are you setting? It should not be larger than diagram.Items.Count - 1, or otherwise the property setter ignores it.
venki5star
Reply #2 - Apr 23rd, 2010 at 12:01pm
I tried setting the Zindex of the ShapeNode to 0 and TableNode to 1.
Castle Rider
Reply #3 - Apr 23rd, 2010 at 1:31pm
Are you setting them after the nodes have been added to the diagram? ZIndex cannot be set before that - it corresponds to the item's index within diagram.Items.
venki5star
Reply #4 - Apr 23rd, 2010 at 2:34pm
Thanks Stoyan. It helped.
Castle Rider
