Normal Topic WPF Diagram 2.3.1 installer has incorrect files (Read 1164 times)
hrumayor
Apr 27th, 2010 at 1:41pm
Hi Stoyo,
WPF Diagram 2.3.1 installer contains an incorrect version for MindFusion.Graphs.dll the installer contains a previous version of the DLL and the MindFusion.Diagramming.Wpf.dll requires a newer one, because the assemblies use strong names it won't graceful use the older version and it fails.
As a work around I am using MindFusion.Graphs.dll of the beta version and it seems to be working fine could you please update the installer to contain the correct DLL.
Hugo
Re: WPF Diagram 2.3.1 installer has incorrect file
Reply #1 - Apr 27th, 2010 at 2:29pm
Have you by chance installed it in the same folder over an older installation? The installer might have not overwritten some of the files... I have tried a clean v2.3.1 install now and everything builds and runs fine.
hrumayor
Reply #2 - Apr 27th, 2010 at 2:54pm
You were right,
I uninstalled the old version, but probably the files remained anyway, I went and erased the files manually and reinstalled and the correct DLL appeared.
Probably the installed does not have the flag to overwrite the destination files, maybe you should create a different folder for each version by including the version on the name.
Hugo
