Hot Topic (More than 10 Replies) rect to ellipse (Read 5925 times)
taxi00driver
rect to ellipse
May 3rd, 2010 at 10:29am
Hi !
I want change drawing item from rect to ellipse.
But i have big trouble with that. Can You help me ??
Bartek,
Re: rect to ellipse
Reply #1 - May 3rd, 2010 at 10:48am
If you are using ShapeNodes, set node.Shape = Shapes.Ellipse, or set diagram.DefaultShape to set it for all new nodes. For other types of nodes you will have to modify their ControlTemplate.
taxi00driver
Re: rect to ellipse
Reply #2 - May 3rd, 2010 at 11:12am
           Dictionary<string, DiagramNode> nodeMap = new Dictionary<string, DiagramNode>();
          Rect bounds = new Rect(0, 0, 60, 20);
           foreach (ItemList x in query12)
               ShapeNode diagramNode = diagram.Factory.CreateShapeNode(bounds);
               nodeMap[x.AtributeID] = diagramNode;
               diagramNode.Text = x.AtributeTITLE;
               peersDict.Add(x.AtributeID, x.AtributePEERS);
           foreach (string itemID in peersDict.Keys)
               string peers = peersDict[itemID];
               string[] peersArr = peers.Split(new string[] { ";#" }, StringSplitOptions.RemoveEmptyEntries);
               for (int i = 0; i < peersArr.Length; i=i+2)
                   diagram.Factory.CreateDiagramLink(
                             nodeMap[itemID],
                             nodeMap[peersArr[i]]);
           LayeredLayout layout = new LayeredLayout();
           layout.Arrange(diagram);
That is my program. End hier i must change rect to somethink like ellipse and add silverlight animiation to nodes and connect lines.
Re: rect to ellipse
Reply #3 - May 3rd, 2010 at 12:04pm
This should create an ellipse:
diagram.Factory.CreateShapeNode(bounds, Shapes.Ellipse)
What kind of animations do you need?
taxi00driver
Re: rect to ellipse
Reply #4 - May 3rd, 2010 at 12:13pm
I wants to add a graphic (change background, add grandian) to change the appearance of nodes and lines (pretty arrows) and then do everything so that flew Cheesy
Re: rect to ellipse
Reply #5 - May 3rd, 2010 at 12:48pm
This fills a node with a gradient:
var brush = new LinearGradientBrush();
brush.GradientStops.Add(new GradientStop { Color = Color.FromArgb(255, 255, 255, 255), Offset = 0.0 });
brush.GradientStops.Add(new GradientStop { Color = Color.FromArgb(255, 255, 220, 200), Offset = 0.2 });
brush.GradientStops.Add(new GradientStop { Color = Color.FromArgb(255, 255, 200, 150), Offset = 1.0 });
brush.StartPoint = new Point(0, 0);
brush.EndPoint = new Point(0.7, 1);
e.Node.Brush = brush;
Do you need to animate the nodes' fill color?
taxi00driver
Re: rect to ellipse
Reply #6 - May 3rd, 2010 at 12:58pm
I want animated all somethink like this: http://quince.infragistics.com/#/ByTag
Re: rect to ellipse
Reply #7 - May 3rd, 2010 at 1:50pm
Currently you can do the color animations by handling the nodes' MouseEnter/Leave events and changing the brush from the handlers.
For version 1.5 we have added some visual states such as Selected / Unselected / MouseOver / MouseOut for which you could define animation storyboards in the nodes' Xaml templates through the VisualStateManager feature of Silverlight. If you wish to try that, you can use this beta build:
https://mindfusion.eu/_beta/diaglite15_states.zip
Position animation can be done by calling SpringLayout.Iterate from a timer. This method is not available for LayeredLayout. If you prefer the latter, you can record the positions of nodes from before and after applying the layout, and then animate the nodes by moving the linearly from the initial to final positions.
taxi00driver
Re: rect to ellipse
Reply #8 - May 3rd, 2010 at 2:02pm
And one more question. How to do a nod to everyone had their specific size? When I trying to change anything goes at it with the same lines are displayed.
Re: rect to ellipse
Reply #9 - May 3rd, 2010 at 2:30pm
You can change the size of nodes through their Bounds property if that's what you are asking.
Re: rect to ellipse
Reply #10 - May 25th, 2010 at 8:29pm
Btw. here's a layout animation sample we are preparing for the next release:
https://mindfusion.eu/_samples/AnimatedLayout.zip
