Normal Topic How to rearrange containers (Read 5595 times)
yrauma
May 10th, 2010 at 6:19pm
Hello Stoyan !
Im still working on my container project Cheesy
I have one last issue.
We are using the feature rearrange to rearrange our graph which worked pretty well before we used containers...
But now troubles have comes.
I would like to use this feature to reorganize the content of a container also not only outside. I found some examples on the forum, but nothing really efficient.
And also is there a way when we add a node into a container programmatically to make it look smarter ? right now when I do that, the container just grows till it is over the node but does not move the node in a logic place...
Any idea ?
Thanks for the help !
Re: How to rearrange containers
Reply #1 - May 10th, 2010 at 7:42pm
You can use this code to arrange a single level of containers and their content:
private void miLayoutContainers_Click(object sender, EventArgs e)
	LayeredLayout layeredLayout = new LayeredLayout();
	layeredLayout.Orientation = MindFusion.Diagramming.Layout.Orientation.Horizontal;
	layeredLayout.StraightenLongLinks = true;
	TopologicalLayout topologicalLayout = new TopologicalLayout();
	topologicalLayout.SplitGraph = true;
	topologicalLayout.Orientation = MindFusion.Diagramming.Layout.Orientation.Vertical;
	Arrange(diagram, topologicalLayout, layeredLayout);
private DiagramItemCollection GetContainerItems(ContainerNode container)
	DiagramItemCollection items = new DiagramItemCollection();
	foreach (DiagramNode node in container.SubordinateGroup.AttachedNodes)
		items.Add(node);
		foreach (DiagramLink link in node.GetAllLinks())
			DiagramNode node2 = GetOtherEnd(link, node);
			if (ContainerNode.GetContainer(node2) == container && !items.Contains(link))
				items.Add(link);
	return items;
private DiagramNode GetOtherEnd(DiagramLink link, DiagramNode node)
	if (node == link.Origin)
		return link.Destination;
	if (node == link.Destination)
		return link.Origin;
	return null;
private void Arrange(Diagram diagram, Layout outerLayout, Layout innerLayout)
	foreach (DiagramNode node in diagram.Nodes)
		ContainerNode container = node as ContainerNode;
		if (container == null)
			continue;
		innerLayout.Arrange(diagram, GetContainerItems(container));
		container.UpdateBounds();
	outerLayout.Arrange(diagram);
	foreach (DiagramLink link in diagram.Links)
		if (ContainerNode.GetContainer(link.Origin) != ContainerNode.GetContainer(link.Destination))
			link.Route();
	diagram.ResizeToFitItems(5);
Experiment with the inner and outer layouts to find ones that will work for your graphs. If your containers can have child containers, you will need to extend the Arrange method to work recursively.
yrauma
Reply #2 - May 10th, 2010 at 8:57pm
Thanks a lot Stoyan !
it works pretty fine !
It actually seems that it works for containers inside container also, at least a little !
Thanks !!!!
