Normal Topic DragAndDrop on Round ShapeNode (Read 2971 times)
granit
May 11th, 2010 at 8:31am
Hello!
I have MindFusion.Diagrammimg lib for WinForms (PE).
For DragAndDrop I use GetNodeAt function.
When I make drop on RectangleNode - it's ok, it's working. But when on RoundNode - GetNodeAt returns null. I have to resize to increase this node, and only after that this function return proper node.
How can it be fixed?
Thanks!
Re: DragAndDrop on Round ShapeNode
Reply #1 - May 11th, 2010 at 9:22am
GetNodeAt works fine for me. Are you converting the drag-and-drop position from screen to view to diagram coordinates? e.g.
PointF point = diagramView.ClientToDoc(
    diagramView.PointToClient(new Point(e.X, e.Y)));
granit
Reply #2 - May 11th, 2010 at 9:35am
this code I use to find node:
Point p = this.PointToClient(new Point(e.X, e.Y));
PointF targetPt = diagramViewMain.ClientToDoc(p);
DiagramNode dn = diagramMain.GetNodeAt(targetPt, true, false);
Thanks, your code works good!
Reply #3 - May 11th, 2010 at 10:31am
You were using the form's PointToClient method and it works now if using DiagramView.PointToClient?
granit
Reply #4 - May 11th, 2010 at 11:47am
Yes.
That code I took from your examples.
