Normal Topic Impossible to create Actor shape node (Read 1997 times)
MUDO
May 11th, 2010 at 12:11pm
Hi again.
I have problem with actor shape made in Shape Designer. It looks like this:
But after I use it, it looks like this:
Code is:
' VB.NET ShapeTemplate definition
   new Shape( _
	 new ElementTemplate() _
	 { _
		new ArcTemplate(40, 0, 60, 20, 90, 360), _
		new LineTemplate(50, 20, 70, 20), _
		new ArcTemplate(64, 20, 75, 30, 270, 90), _
		new LineTemplate(75, 25, 75, 60), _
		new LineTemplate(75, 60, 68, 60), _
		new LineTemplate(68, 60, 68, 30), _
		new LineTemplate(68, 30, 64, 30), _
		new LineTemplate(64, 30, 64, 100), _
		new LineTemplate(64, 100, 52, 100), _
		new LineTemplate(52, 100, 52, 65), _
		new LineTemplate(52, 65, 48, 65), _
		new LineTemplate(48, 65, 48, 100), _
		new LineTemplate(48, 100, 36, 100), _
		new LineTemplate(36, 100, 36, 30), _
		new LineTemplate(36, 30, 32, 30), _
		new LineTemplate(32, 30, 32, 60), _
		new LineTemplate(32, 60, 25, 60), _
		new LineTemplate(25, 60, 25, 25), _
		new ArcTemplate(25, 20, 38, 30, 180, 90), _
		new LineTemplate(30, 20, 50, 20) _
	 }, _
	 { _
	 }, _
	 { _
		new LineTemplate(36, 22, 64, 22), _
		new LineTemplate(64, 22, 64, 64), _
		new LineTemplate(64, 64, 36, 64), _
		new LineTemplate(36, 64, 36, 22) _
	 }, _
  FillMode.Winding,   "test" )
I want text area only inside actor.
Any idea?
...MUDO...
Re: Impossible to create Actor shape node
Reply #1 - May 11th, 2010 at 12:33pm
You might have moved or removed some point inadvertently. If you only need to change the text region, try setting Shapes.Actor.TextArea to the array from your code.
