Normal Topic Swimlanes and links (Read 1434 times)
fireboy
Swimlanes and links
May 17th, 2010 at 3:06pm
I have a diagram that contains swimlanes (implemented as nodes with ZIndex=0, Obstacle=false, AllowIncomingLinks=false and AllowOutgoingLinks=false).
When a link is above the swimlane, it is impossible to select the link by clicking on it, regardless of the fact that link's ZIndex is higher. The swimlane always gets selected. The other portions of the link can be selected normally (if there are no swimlanes below them).
Is it possible to change this behavior? Maybe it is possible to override swimlanes to enable hit testing only on non-empty areas.
Or prioritize link hit testing?
Re: Swimlanes and links
Reply #1 - May 17th, 2010 at 3:09pm
Set Diagram.HitTestPriority = ZOrder.
fireboy
Reply #2 - May 17th, 2010 at 3:24pm
Worked like a charm, thanks!
