Normal Topic Where to get license information from? (Read 3553 times)
leSasch
May 18th, 2010 at 9:11am
we got the Scheduling component licensed.
Isn't there any license-number?
We just have the pretty old installer from 10.03.2010 - nothing more.
Thanks for info.
Re: Where to get license information from?
Reply #1 - May 18th, 2010 at 10:27am
This is currently the last official release of MindFusion.Scheduling for WPF. If there is a feature from the pre-release builds, which is not available there, I can send you the most recent version of the control. Otherwise, you will be able to download the version from the clients area once it is released.
springy
Reply #2 - Jul 6th, 2010 at 8:33am
While setting up a build server I wonder what exactly is needed so that the resulting executables don't accidentally show a "evaluation/trial version" label?
/\/\arkus.
Reply #3 - Jul 6th, 2010 at 8:55am
You will have to use the licensed assemblies, that is, the assemblies installed with the licensed setup. In addition you will have to export the licensing information from the Windows registry under the following key and reimport it on the build server:
HKEY_LOCAL_MACHINE\SOFTWARE\MindFusion\ComponentLicenses
Let me know if this helps.
