Normal Topic Keep link's textblock location when a node is move (Read 2566 times)
alexbisson
May 20th, 2010 at 7:22pm
I've added a key down event on the diagram to let the user move a link's textblock with the arrow keys, by setting the TextBlock.Margin property.
However, when a node connected to the link is moved, the textblock goes back to its original position (center of the link).
Is there a way to keep the textblock's relative position when one of the connecting nodes is moved?
Thank you!
Re: Keep link's textblock location when a node is
Reply #1 - May 20th, 2010 at 7:41pm
If by chance you are using a custom link class, you can do that by overriding the UpdateTextLayout method. Otherwise I suppose we could add some property to let you override the label position easier.
alexbisson
Reply #2 - May 21st, 2010 at 3:26pm
I've subclassed DiagramLink but an exception is thrown when an unconnected link is added..I've been able to reproduce it in a sample application:
1. Add a Diagram and NodeListView with a few shapes on a silverlight page
2. Set the property :
Diagram.AllowUnconnectedLinks = false
3. Create a custom Link class:
public class LinkBase : DiagramLink
    public LinkBase(Diagram diagram) : base(diagram) { }
4. Create a custom behavior class:
public class DiagramBehavior : DrawLinksBehavior
        public DiagramBehavior(Diagram diagram) : base(diagram) { }
        protected override DiagramLink CreateLink(DiagramNode origin, Point point)
            LinkBase link = new LinkBase(Diagram);
            link.Origin = origin;
            return link;
5. Add:
diagram.CustomBehavior = new DiagramBehavior(diagram);
6. Now drag a node on the diagram, and draw a link pointing to nothing. Since AllowUnconnectedLinks is set to false, the link is deleted. However, a null reference is thrown in a method called by MindFusion.Silverlight.Diagram.RemoveItem().
This happens only when subclassing DiagramLink.
Are you able to reproduce this behavior? If so, is there a workaround?
Thanks!
Reply #3 - May 21st, 2010 at 5:48pm
Change CreateLink to this:
	link.Destination = Diagram.Dummy;
	return link;
Or add and use a constructor that calls the base DiagramLink(Diagram, node, point) constructor.
alexbisson
Reply #4 - May 21st, 2010 at 5:58pm
Works great. Smiley Thank you for your help!
