Normal Topic Resize nodes based on changing text (Read 1461 times)
Sam
May 21st, 2010 at 8:50am
Hi, we want to allow an option to show either detailed or summary text in the node, but when changing the text property of the node it doesn't resize.  I sthere a method I can call to resize the noed such that it fits the text?  I can see a ResizeToFitText method in the ASP.NET documentation but not the Windows Forms.
Re: Resize nodes based on changing text
Reply #1 - May 21st, 2010 at 8:59am
There is ResizeToFitText method in Windows Forms too. It's defined in ShapeNode, TableNode and TreeViewNode. You can't call it through the base DiagramNode class though - the different nodes take different kinds of arguments for their resize methods so it's not defined in the base class.
