Normal Topic Tooltips on items (Read 2976 times)
Jos
Tooltips on items
May 25th, 2010 at 7:12am
I was wondering if there is an easy way to use tooltips on Items.
I've made custom templates with the use of your online help, but cannot find any help on how to implement tootltips.
Could you point me in the right direction?
Kind regards,
Jos ter Doest
WiZZiX
Re: Tooltips on items
Reply #1 - May 25th, 2010 at 7:50am
Have you tried setting the ToolTipService.ToolTip attached property on the root element of your template? For example, if the root element in your template is a Grid, here is a code associating a tooltip with this element:
<Grid ToolTipService.ToolTip="Hello" ...
Let me know if this helped.
Jos
Reply #2 - May 26th, 2010 at 6:58am
My root element is the ResizeBand and it's working fine. Should have known it was that easy  Embarrassed
Grtz, Jos
