Normal Topic Licensing for DiagramLite together with NetDiagram (Read 1896 times)
jonas
May 27th, 2010 at 2:33pm
I am planning to build an diagramming application that  utilizes DiagramLite for clients supporting Silverlight and NetDiagram ImageMap for those clients that do not allow installing Silverlight.
What license/licenses should I buy?
Is there a package including both DiagramLite and NetDiagram?
Best regards,
Jonas
Re: Licensing for DiagramLite together with NetDia
Reply #1 - May 27th, 2010 at 3:00pm
NetDiagram is enough; with it you also get the diagramlite assembly for use in the Silverlight mode. You can use it in standalone Silverlight apps too if you wish.
Since the Diagramlite version coming with NetDiagram is a bit older, drop me a message after registering at out clients site http://clientsarea.eu/ and we'll also add the latest Diagramlite release to your account.
jonas
Reply #2 - May 27th, 2010 at 3:05pm
Great!
So this means that if I buy NetDiagram with sourcecode and subscription for upgrades, I will also get source code and upgrades for DiagramLite?
Best Regards,
Jonas
Reply #3 - May 27th, 2010 at 3:08pm
Yep, and you also get the Java code for the applet Wink
