Normal Topic Edit text on diagramnode (Read 1474 times)
dmz
May 28th, 2010 at 8:19am
Hi.
I'm new so sorry if the question is quite stupid.
I have created a diagram of diagramnodes containing different shapes.
Can I edit the text on one of the nodes. I can't find the way to do this. I have tried to do it from the node itself and from the diagram but I can't find a way.
Something like this...
DiagramNode Item ...
Item.shapeText/Text???
Re: Edit text on diagramnode
Reply #1 - May 28th, 2010 at 9:05am
If you need a way to do that interactively, enable AllowInplaceEdit and double click, or call DiagramView.BeginEdit in response to some event handler.
To do that from code, you'll need to type-cast to ShapeNode and set ShapeNode.Text.
dmz
Reply #2 - May 28th, 2010 at 10:21am
Thanks a lot.. It works perfectly..
