Normal Topic ZoomToRect calls with an overview: OutOfMemory (Read 3291 times)
alexbisson
May 31st, 2010 at 3:53pm
I get OutOfMemory exceptions when I call the Diagram.ZoomToRect() method when an Overview is used.
Sample project to reproduce my behavior:
Markup:
<Grid x:Name="LayoutRoot" Background="White">
        <Grid.ColumnDefinitions>
            <ColumnDefinition Width="*"></ColumnDefinition>
            <ColumnDefinition Width="Auto"></ColumnDefinition>
        </Grid.ColumnDefinitions>
        <diag:Diagram x:Name="diagram" Grid.Column="0"
                      Bounds="0, 0, 800, 800"
                      BackBrush="LightSteelBlue"
                      NodeDoubleClicked="diagram_NodeDoubleClicked"/>
        <StackPanel Orientation="Vertical" Grid.Column="1" >
            <diag:NodeListView x:Name="nodeListView"  />
            <diag:Overview x:Name="diagOverview"></diag:Overview>
            <Button Content="Default zoom" Click="Button_Click" />
        </StackPanel>
    </Grid>
Code behind:
public MainPage()
            InitializeComponent();
            nodeListView.Items.Add(new ShapeNode() { Text = "Node 1" });
            nodeListView.Items.Add(new ShapeNode { Text = "Node 2" });
            diagOverview.Document = diagram;
        private void diagram_NodeDoubleClicked(object sender, NodeEventArgs e)
            diagram.ZoomToRect(e.Node.Bounds);
        private void Button_Click(object sender, RoutedEventArgs e)
            diagram.ZoomFactor = 100;
If a double-click on a node then click "Default zoom" several times, the memory usage jumps, eventually throwing an OutOfMemory Exception from the Overview.Update() method.
Everything works fine if I comment the following line in the constructor:
Thank you!
alex
Re: ZoomToRect calls with an overview: OutOfMemory
Reply #1 - May 31st, 2010 at 5:11pm
Yes, we were able to reproduce this. The overview creates a new WriteableBitmap(diagram) at one point and it gets too big when ZoomFactor is a large number. We'll try creating a smaller image using the WriteableBitmap(diagram, ScaleTransform) constructor to see if that will help.
alexbisson
Reply #2 - May 31st, 2010 at 6:36pm
Will it be fixed in the next version? If so, what's the expected release date?
Reply #3 - Jun 1st, 2010 at 4:31pm
This version should fix that:
https://mindfusion.eu/_beta/diaglite16_ovw.zip
We should release it next week.
alexbisson
Reply #4 - Jun 2nd, 2010 at 6:18pm
Thank you!
