Normal Topic Poor routing performance of links (Read 2308 times)
lutz
Jun 1st, 2010 at 1:59pm
we have a collection of links which we like to route.
Currently we call link.Route() which takes for 80 links up to 5 minutes to be done.
What is the most efficient approach to route those links?
Regards
Lutz
Re: Poor routing performance of links
Reply #1 - Jun 1st, 2010 at 2:28pm
Call new QuickRouter(diagram).RouteLinks(linkCollection);
lutz
Reply #2 - Jun 1st, 2010 at 3:16pm
Hi Stoyan,
this is much, much faster - but the origin and destination Anchorpoints are not kept.
Any idea?
Lutz
Reply #3 - Jun 1st, 2010 at 3:56pm
Hi Lutz,
Were you using the RoutingOptions.Anchoring property set to Reassign? GridRouter would assign links to anchor points in such case, but QuickRouter ignores that value and should always preserve the current end points of the links. If that's the problem, you could call ReassignAnchorPoints() on the links before running QuickRouter.
lutz
Reply #4 - Jun 1st, 2010 at 4:44pm
Hi Stoyan,
this works fine now.
Thank you very much
Lutz
