Normal Topic moving appointments (Read 5102 times)
thierry
moving appointments
Jun 3rd, 2010 at 3:38pm
I am a new user of the Scheduling Library.
I use the library as a ResourceView and when I move an appointment I wish that this one moves on a particular segment of hour (between the 10 am and the 2 pm for example).
I do it with no problem at all on a resizeStart or ResizeEnd in ItemModifying but not when the appointment is entirely moved (Drag and Drop).
I have tried alot of the setting and searched the forum but I could not get any solution.
Best Regards,
Thierry
Re: moving appointments
Reply #1 - Jun 3rd, 2010 at 4:08pm
Can you post the code of your ItemModifying event handler?
thierry
Reply #2 - Jun 3rd, 2010 at 4:27pm
This is the code.
void calendar1_ItemModifying(object sender, ItemModifyConfirmEventArgs e) {
TimeSpan _hourbegin = new TimeSpan(14, 0, 0);
TimeSpan _hourend = new TimeSpan(10, 00, 00);
// this one is good !
if (e.ResizeStart) {
if (e.Item.StartTime.Date < e.NewStartTime.Date) {
TimeSpan substractValue = TimeSpan.FromHours(e.NewStartTime.Hour) + TimeSpan.FromMinutes(e.NewStartTime.Minute) + TimeSpan.FromSeconds(e.NewStartTime.Second);
DateTime newDate = e.NewStartTime.Subtract(substractValue);
e.NewStartTime = newDate + _hourbegin;
if (e.Item.StartTime.Date > e.NewStartTime.Date) {
e.NewStartTime = e.NewStartTime + _hourbegin;
// this one is not !
if (!e.ResizeStart && !e.ResizeEnd) {
TimeSpan itemDuration = e.Item.EndTime - e.Item.StartTime;
e.NewEndTime = e.NewStartTime + itemDuration;
Best Regards,
Thierry
Reply #3 - Jun 4th, 2010 at 6:20am
Can you try the following code and see if it suits your needs:
TimeSpan start = new TimeSpan(10, 00, 00);
TimeSpan end = new TimeSpan(14, 0, 0);
if (!e.ResizeEnd)
      // Moving or resizing start
      e.Confirm = (e.NewStartTime.TimeOfDay >= start && e.NewStartTime.TimeOfDay <= end);
else
      // Resizing end
      e.Confirm = (e.NewEndTime.TimeOfDay >= start && e.NewEndTime.TimeOfDay <= end);
The code checks if the start and end time of the item are in the valid range and if not - rejects the current operation.
thierry
Reply #4 - Jun 4th, 2010 at 7:47am
Thanks for the response, I think your code is a part of what I am searching for.
Unfortunately as the resourceview is parametrized on:
[code]
calendar1.ResourceViewSettings.BottomTimelineSettings.Unit = TimeUnit.Day;
calendar1.ResourceViewSettings.BottomTimelineSettings.UnitCount = 1;
[/code]
When I move an item this one is moved systematically on midnight and so your code is always at false.
How could I solve this problem.
Best regards,
Thierry
Reply #5 - Jun 4th, 2010 at 8:23am
Yes, items snap to days by default. In order to disable day snapping, use the following line:
calendar1.ResourceViewSettings.SnapUnit = TimeUnit.Second;
Let me know if this works.
thierry
Reply #6 - Jun 4th, 2010 at 11:09am
A last point, how could I magnetize the movement of an appointment, when it goes into an interval of + or - three hours of the hour which it have to stick (as you make it with calendar1. ResourceViewSettings. SnapUnit = TimeUnit. Day when you come to place the appointment at midnight on a drag and drop operation).
Best regards,
Thierry
Reply #7 - Jun 4th, 2010 at 12:00pm
I managed to achieve the desired custom snapping but the implementation turned out rather long.
private void calendar1_ItemModifying(object sender, ItemModifyConfirmEventArgs e)
	bool moving = !e.ResizeStart && !e.ResizeEnd;
	if (!modifying)
		initialItemStartTime = e.Item.StartTime;
		initialItemEndTime = e.Item.EndTime;
		offset = TimeSpan.Zero;
		previousStartTime = e.Item.StartTime;
		previousEndTime = e.Item.EndTime;
	if (moving)
	if (e.ResizeStart || moving)
		offset += e.NewStartTime - previousStartTime;
	else
		offset += e.NewEndTime - previousEndTime;
	previousStartTime = e.NewStartTime;
	previousEndTime = e.NewEndTime;
	TimeSpan snapAt = new TimeSpan(12, 0, 0); // Snap at 12:00
	TimeSpan snapTollerance = new TimeSpan(3, 0, 0); // Snap when the items are within 3 hours of the snap time
	TimeSpan displace = TimeSpan.Zero;
		DateTime expectedStartTime = initialItemStartTime + offset;
		// Align the time
		if (expectedStartTime.TimeOfDay >= snapAt - snapTollerance &&
			expectedStartTime.TimeOfDay <= snapAt + snapTollerance)
			displace = expectedStartTime.Date + snapAt - expectedStartTime;
			expectedStartTime = expectedStartTime.Date + snapAt;
		e.NewStartTime = expectedStartTime;
	if (moving)
		DateTime expectedEndTime = initialItemEndTime + offset + displace;
		e.NewEndTime = expectedEndTime;
	if (e.ResizeEnd)
		DateTime expectedEndTime = initialItemEndTime + offset;
		// Align the time
		if (expectedEndTime.TimeOfDay >= snapAt - snapTollerance &&
			expectedEndTime.TimeOfDay <= snapAt + snapTollerance)
			expectedEndTime = expectedEndTime.Date + snapAt;
	modifying = true;
private void calendar1_ItemModified(object sender, ItemModifiedEventArgs e)
	modifying = false;
private bool modifying = false;
private DateTime initialItemStartTime;
private DateTime initialItemEndTime;
private DateTime previousStartTime;
private DateTime previousEndTime;
private TimeSpan offset;
Note, that now we are also handling the ItemModified event as well and have declared several member variables.
thierry
Reply #8 - Jun 4th, 2010 at 12:29pm
Thanks for your response.
That's exactly what I want.
I really appreciate your support and time spent to help me.
Best regards,
Thierry
