Normal Topic Xml Version problem (Read 1155 times)
andrejz
Xml Version problem
Jun 8th, 2010 at 11:36am
Hi, we are in need of displaying Xml diagram in Silverlight, which were drawn in WinForms App.
However, Winforms saves diagrams using "Version 13" Xml format, and Silverlight diagrams use "Version 12".
The simplest solution would be to try older WinForms diagrams. Where van we find older version of MindFusion fiagrams for WinForms? I cannot find any links to old versions or something like that on Your page.
Re: Xml Version problem
Reply #1 - Jun 8th, 2010 at 12:10pm
The most recent versions of both components should save in a "version 14" format. Try these releases:
V5.3.5 for Winforms:
V1.6 for Silverlight:
https://www.mindfusion.eu/DiagramLiteTrial.zip
If you have an account at http://clientsarea.eu/ you can find a few older versions there too.
andrejz
Reply #2 - Jun 8th, 2010 at 12:36pm
Thanks a lot!
