Normal Topic TimelineStyle - Hour line (Read 3651 times)
matt.s
Jun 9th, 2010 at 10:03am
I'm using the TimeTable view of the calendar, and would like to have a line between each hour on the time line, in much the same way that Outlook has.
Is this possible?
Matt
Re: TimelineStyle - Hour line
Reply #1 - Jun 9th, 2010 at 10:20am
There should be a line displayed between the hours in the timetable timeline. You can adjust the color of this line through the Calendar.TimetableSettings.TimelineStyle.LineBrush property.
Let me know if this helps.
matt.s
Reply #2 - Jun 9th, 2010 at 2:26pm
I have narrowed it down. The lines are removed if I set the StartTime as follows;
calendar.TimetableSettings.StartTime = (8 * 60);
Is this expected behaviour?
Matt
Reply #3 - Jun 9th, 2010 at 2:41pm
This is indeed the case. We will look into this and I will get back to you as soon as possible.
