Normal Topic Vertical Scrollbar (Read 3023 times)
matt.s
Vertical Scrollbar
Jun 9th, 2010 at 2:44pm
I can't find a way of hiding the vertical scrollbar in TimetableSettings.
What I am trying to do is mimic Outlook which only has one scroll bar to the right of all the calendars.
I achived this using the WinForms control by turning off the vertical scrollbar for all calendars except for the right most calendar.
This scrollbar then set the ScrollPosition on all the diaries to the same value when the scroll event was fired, which meant that all the diaries moved up and down together.
Can I do this with the WPF control?
Thanks!
Matt
Re: Vertical Scrollbar
Reply #1 - Jun 10th, 2010 at 8:48am
You can download a preliminary version of MindFusion.Scheduling for WPF from the link below:
https://mindfusion.eu/_pln_trial/MindFusion.Scheduling.Wpf.2.1.1a.zip
The new version should fix the issue with the timeline separators between hours. In addition, the Calendar control now exposes two new properties - HorizontalScrollBarVisibility and VerticalScrollBarVisibility, which you can use to control the visibility of the scrollbars.
Let me know if this helps.
P.S.: These changes will be available in the forthcoming release of MindFusion.Scheduling for WPF, which is expected until the end of June.
matt.s
Reply #2 - Jun 10th, 2010 at 9:24am
Hi Meppy,
Yes this build has fixed the hour line problem and the scrollbar visibility properties are working fine.
I'm now able to mimic the scrolling behaviour found in Outlook, which is great.
Matt
