Normal Topic Drag Drop (Read 5585 times)
matt.s
Drag Drop
Jun 10th, 2010 at 12:24pm
Does the calendar support drag and drop events?
I have set AllowDrop to True, but nothing is fired in the Drop or DragOver events of a calendar.
I'm trying to drap/drop appointments between two diaries.
Matt
Re: Drag Drop
Reply #1 - Jun 10th, 2010 at 1:08pm
I subscribe to the events and they fire as expected. What code are you using?
matt.s
Re: Drag Drop
Reply #2 - Jun 10th, 2010 at 1:24pm
My XAML is as follows;
    <Grid>
        <Grid.ColumnDefinitions>
            <ColumnDefinition Width="*" />
        </Grid.ColumnDefinitions>
        <planner:Calendar Name="calendar1"
                          Grid.Column="0"
                          Theme="Windows2003"
                          CurrentView="Timetable"
                          AllowInplaceCreate="False"
                          AllowInplaceEdit="False"/>
        <planner:Calendar Name="calendar2"
                          Grid.Column="1"
                          Theme="Windows2003"
                          AllowDrop="True"
                          Drop="calendar_Drop"
                          DragOver="calendar_DragOver" />
    </Grid>
My code behind creates dates and a resource for each calender, and an appointment for calendar1.
When I drag the appointment from calendar1 to calendar2, neither the Drop or DragOver events fire.
Re: Drag Drop
Reply #3 - Jun 10th, 2010 at 1:37pm
Modifying an appointment interactively within the calendar is not considered a Windows drag&drop operation. It is a native operation for the Calendar control which is only effective within the control.
In order to initiate a true Windows (cross-control and cross-application) drag&drop, you need to invoke the System.Windows.DragDrop.DoDragDrop static method. I found that a very convenient place to initiate this operation is in the ItemClick event of the source Calendar control (calendar1 in your case).
My event handler looks similar to the following:
private void calendar1_ItemClick(object sender, ItemMouseEventArgs e)
      calendar1.ResetDrag();
      DragDrop.DoDragDrop(calendar1, e.Item, DragDropEffects.Copy);
Let me know if this works.
matt.s
Re: Drag Drop
Reply #4 - Jun 10th, 2010 at 3:29pm
Yes you are right - this is now working fine.
How do you get the drop location? I have the code below, but it always returns a null datetime.
            Point p = e.GetPosition(calendar);
            Point pt = this.PointToScreen(p);
            // get the start/end time of the drop location
            DateTime? startTime = calendar.GetDateAt(pt);
            if (!startTime.HasValue)
                return;
Matt
Re: Drag Drop
Reply #5 - Jun 11th, 2010 at 5:44am
The point supplied as argument should be in calendar coordinates. Therefore, in your case, simply pass p.
Let me know if this helps.
matt.s
Re: Drag Drop
Reply #6 - Jun 14th, 2010 at 2:43pm
Yes - this works.
Thanks for your help.
