Normal Topic Adding comments in diagram (Read 3768 times)
Naganathan
Jun 14th, 2010 at 5:26am
Can anyone suggest a way to add comment text(editable) in the diagram..
FYI. We have created a custom control derived from ControlNode and and added a TextBlock to that..The TextBlock has MaxWidth and TextWrapping set to 100.And the X,Y position of the comment text is stored in database.Now the problem is the textbox is displayed with the default size of 50,50 automatically and there is noway i could find to display the complete text.
Appreciate your help..
Naganathan NS
Re: Adding comments in diagram
Reply #1 - Jun 14th, 2010 at 6:44am
You can measure text size as shown in the post below, and set your node size based on the result:
http://mindfusion.eu/Forum/YaBB.pl?board=diaglite_disc;action=display;num=127182...
Instead of custom control you could use a ShapeNode and call its ResizeToFitText method. Set the node's Transparent property to true to hide its geometry and leave only the text visible, if that's what you need for the comment text.
Naganathan
Reply #2 - Jun 14th, 2010 at 8:25am
Hi Stoyan,
Thanks for the quick reply..I tried with ShapeNode and called ResizeToFitText() method after assigning the text. Please have a look at my code.
public ShapeNode1(Diagram diagram,Comment comment) : base(diagram)
this.Text = comment.TextComment;
this.TextWrapping = System.Windows.TextWrapping.Wrap;
this.MaxWidth = 100;
ResizeToFitText();
Rect rec = this.GetBounds();
rec.X = comment.XPosition;
rec.Y = comment.YPosition;
this.SetBounds(rec, true);
this.UpdateVisuals();
But for some reason,the shapenode is displayed without wrapping with respect to the MaxWidth set to 100..Please tell me whats wrong in this code and it would be helpful if u can share some sample code..
Naganathan NS
Reply #3 - Jun 14th, 2010 at 9:12am
I'm afraid ResizeToFitText does not honor MaxWidth at this time. The code in that post is a copy of the ResizeToFitText body - try adding a MaxWidth setter to the TextBlock init block and using that code instead of the built-in ResizeToFitText.
Naganathan
Reply #4 - Jun 14th, 2010 at 9:52am
Hi Stoyan,
I tried the other approach using TextBlock and unfortunately it did not help me to solve the issue..copied the code for your reference...
var textBlock = new TextBlock
Text =comment.TextComment,
TextWrapping = TextWrapping.Wrap,
MaxWidth = 100,
Width = double.NaN,
Height = double.NaN,
FontFamily = FontFamily,
FontSize = FontSize
textBlock.UpdateLayout();
Size desiredSize = new Size(
textBlock.ActualWidth + TextMargin.Left + TextMargin.Right + StrokeThickness * 2,
textBlock.ActualHeight + TextMargin.Top + TextMargin.Bottom + StrokeThickness * 2);
Rect newBounds = new Rect(new Point(comment.XPosition, comment.YPosition), desiredSize);
this.SetBounds(newBounds, true);
Reply #5 - Jun 14th, 2010 at 11:24am
Right, setting MaxWidth alone seems to not have any effect. I've managed to measure the size by inserting the TextBlock into a grid as below. I don't know if all parts of the code are necessary, you might experiment removing some of them:
var node = diagram.Factory.CreateShapeNode(0, 0, 10, 10);
string text = "But for some reason,the shapenode is displayed without wrapping with respect to the MaxWidth set to 100";
	Text = text,
	MaxWidth = 100,
	Width = double.NaN,
	FontFamily = node.FontFamily,
	FontSize = node.FontSize
var grid = new Grid();
grid.ColumnDefinitions.Add(new ColumnDefinition {MaxWidth = 100});
grid.Children.Add(textBlock);
diagram.DocumentPlane.Children.Add(grid);
grid.UpdateLayout();
//textBlock.Measure(new Size(100, double.PositiveInfinity));
//textBlock.Arrange(new Rect(new Point(), textBlock.DesiredSize));
node.Bounds = new Rect(node.Bounds.X, node.Bounds.Y, textBlock.ActualWidth, textBlock.ActualHeight);
node.TextWrapping = TextWrapping.Wrap;
diagram.DocumentPlane.Children.Remove(grid);
