Normal Topic Strange error... possible Mindfusion? (Read 3202 times)
radu
AMADEE
Jun 22nd, 2010 at 7:14am
Hi
On one laptop we experience a very strange behavior... it happens when we try to dock back a specific toolwindow by dropping it over any of the docking "icons". If we do it using the "Dock" option in the menu it works fine, no problems. We are using Actipro Docking components and the only control inside the ToolWindow is the WPF Diagram.
Actipro said they don't use COM so the error is not coming from them... therefore I ask you too... maybe you have an idea..
The error thrown is:
Exception from HRESULT: 0x88980406
System.Runtime.InteropServices.COMException (0x88980406): Exception from HRESULT: 0x88980406 at System.Windows.Media.Composition.DUCE.Channel.SyncFlush() at System.Windows.Interop.HwndTarget.UpdateWindowSettings(Boolean enableRenderTarget, Nullable`1 channelSet) at System.Windows.Interop.HwndTarget.UpdateWindowPos(IntPtr lParam) at System.Windows.Interop.HwndTarget.HandleMessage(WindowMessage msg, IntPtr wparam, IntPtr lparam) at System.Windows.Interop.HwndSource.HwndTargetFilterMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled) at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled) at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o) at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs) at MS.Internal.Threading.ExceptionFilterHelper.TryCatchWhen(Object source, Delegate method, Object args, Int32 numArgs, Delegate catchHandler)
Source: Presentation.Core
It is a Win7 Terra laptop with .NET 4 installed.
Do you have any idea why is this happening?
Re: Strange error... possible Mindfusion?
Reply #1 - Jun 22nd, 2010 at 8:43am
This comes from the WPF rendering thread. Try enabling software rendering as shown in this post (6. New Software rendering API ):
http://blogs.msdn.com/b/jgoldb/archive/2007/10/10/performance-improvements-in-wp...
If the error disappears, this usually means there's something wrong with the video driver.
radu
AMADEE
Reply #2 - Jun 22nd, 2010 at 10:25am
That was first thing we tried, as described here (we target .NET 4): http://blogs.msdn.com/b/jgoldb/archive/2010/04/12/what-s-new-for-performance-in-...
Now we can reproduce it on another laptop too (XP this time)
radu
AMADEE
Reply #3 - Jun 22nd, 2010 at 2:24pm
It seems the problem disappears if we remove the diagram from the toolwindow...
radu
AMADEE
Reply #4 - Jun 23rd, 2010 at 10:28am
We could reproduce the problem with toolwindows without Mindfusion components inside.
That means case is closed here  Roll Eyes
Thx for support. Topic can be closed.
