Normal Topic Virtual Diagram that represent multi diagrams (Read 2194 times)
solisgsandc
Jun 25th, 2010 at 3:37pm
Is there a way to collect all physical diagram  nodes, links, diagram items into a virtual diagram concept? I am investigating this strategy to divide the big diagram into manageable pieces. Is there also a diagram connector concept that connects all diagrams together.
Re: Virtual Diagram that represent multi diagrams
Reply #1 - Jun 25th, 2010 at 5:10pm
Do you mean splitting the data into several subsets displayed in different diagrams?
solisgsandc
Reply #2 - Jun 25th, 2010 at 8:12pm
Yes. I am trying to come up with a way to deal with performance problems with thousands of controls in one diagram. Unless there is another idea such as making nodes invisible if not in viewing area.
I am looking at the concept of diagram that is related to 1 or many adjacent diagrams.
The relation is needed to know so that if I were to find a particular node that I am able to find this in adjacent diagrams. Also I could follow link connections to another diagram.
I hope I am explaining myself clearly.
Reply #3 - Jun 28th, 2010 at 8:03am
This would be similar to ItemsControl virtualization, but the WPF built-in virtualization works only for lists. We'll see if we can implement a two-dimensional variant in a future release.
If you know how the big diagram should be divided into subsets, you can build a graph that represents the connections between these subsets, where a graph vertex represents a set in the original diagram. E.g. if node from set A is connected to node in set B, then you also have an edge connecting A and B in the representative graph. This would let you find related subsets quickly, and you can use "off-page connection" shapes as in Visio to represent the other ends of links whose node are in different sets. You could also run some layout algorithm on that representative graph to get the relative positions of different sets and so to determine where in the diagram to draw off-page connections in the currently display set.
