Normal Topic License issue (Read 4078 times)
yrauma
License issue
Jun 29th, 2010 at 3:18pm
Hello Stoyan,
I just integrated the latest version of MindFusion into my project.
Unfortunately, it seems that I have license issues.
I have this error :
Error8Exception occurred creating type 'MindFusion.Diagramming.WinForms.DiagramView, MindFusion.Diagramming.WinForms, Version=5.3.5.25868, Culture=neutral, PublicKeyToken=XXXXXXX' System.ComponentModel.LicenseException: Couldn't get design-time license for ''MindFusion.Diagramming.WinForms.DiagramView''D:\[...]\licenses.licx
I obviously left the old license file, but the new ones I got in the samples does not work better.
Am I supposed to get a new file from somewhere ? is it somehow generated ?
Amaury
Re: License issue
Reply #1 - Jun 29th, 2010 at 4:34pm
Hi Amaury,
Edit licenses.licx and set PublicKeyToken=null at the end of the line.
yrauma
Re: License issue
Reply #2 - Jun 29th, 2010 at 5:49pm
its not working. Sad
I put
MindFusion.Diagramming.WinForms.DiagramView, MindFusion.Diagramming.WinForms, Culture=neutral, PublicKeyToken=null
in the file
and still the error :
Error8Exception occurred creating type 'MindFusion.Diagramming.WinForms.DiagramView, MindFusion.Diagramming.WinForms, Version=5.3.5.25868, Culture=neutral, PublicKeyToken=XXXXXXX' System.ComponentModel.LicenseException: Couldn't get design-time license for ''MindFusion.Diagramming.WinForms.DiagramView''D:\[..].licx
EDIT : I also try to put in the file
MindFusion.Diagramming.WinForms.DiagramView, MindFusion.Diagramming.WinForms, Version=5.3.5.25868, Culture=neutral, PublicKeyToken=null
same error....
Re: License issue
Reply #3 - Jun 29th, 2010 at 6:41pm
If you uninstalled an older version after installing the new one, that might have removed the required registry license keys. Try installing again in such case.
yrauma
Re: License issue
Reply #4 - Jun 29th, 2010 at 6:43pm
Exactly,
I just figured it out before you answered.
Removing the previous version erased the register key...
Thamk you Stoyan
